I know there are a million threads with timecode advice, but I've read a ton and none seem to be able to help....
Basically, my problem is that my timecodes signal swings wildly from 1% to 100%. They show up and are recognized fine and my soundcard is working perfectly. I've played around with settings in the timecode configuration and in VDJ config, but nothing seems to help. Any suggestions?
Gear:
VDJ Pro 6.07
Stanton T60s
Maya44 USB
Serato Scratch V2 time codes
Gear:
VDJ Pro 6.07
Stanton T60s
Maya44 USB
geposted Sat 03 Apr 10 @ 10:48 pm
The only thing I can think of is if you're using "side A" on the Serato timecodes make sure that "side A" is selected in the config menu. Using the wrong "side" in the config menu will result in the problem you described.
geposted Sun 04 Apr 10 @ 11:43 am
Thanks for the response, but I am using Side A with the "Side A" setting on.... do you think it's possibly hardware issue within the sound card?
geposted Sun 04 Apr 10 @ 7:17 pm
I forgot to mention, the other things that can cause the timecode signal to fluctate is dirty/dusty or worn out timecodes, worn out needles, or too much weight on the headshell (i.e. incorrect turntable set-up). You might find if you get new needles and timecodes that the signal will be steadier.
geposted Sun 04 Apr 10 @ 8:24 pm
I'll try cleaning the needles and the records, but the vinyls are also brand new (I opened the package 2 days ago).
geposted Sun 04 Apr 10 @ 10:19 pm
