I have used the hercules RMX for about 6 months and enjoy it much, but ready to move on to something a little bit more advanced. I feel like its a pretty simple controller and was great for starting out with but looking for something with more options available to me. It seems that virtual dj is pretty high on the hercules for its compatibility but regardless I think its still a pretty simple mixer. Also I only really need something with 2 channels for where I am at as a still learning a lot dj. (have been djing seriously for only a year)
I'll have about $400-$600 to spend.
I've considered getting the Pioneer DJM-400 and just foregoing any platters or cdj decks(I don't have the money for both). I figured this could work since I am not really a "scratching turntablist" but rather just a DJ who blends electro and house music together. I guess if people think I'd be fine with just a mixer, recommend those too. Any advice or recommendations would really be helpful to me.
thanks,
-King Pin
thanks,
-King Pin
geposted Sun 04 Apr 10 @ 2:56 am
Keep an eye out for the American Audio VM4 controller thats coming out soon...looks pretty cool but quite similar to RMX.
geposted Sun 04 Apr 10 @ 3:29 am
What about something extra to add to your setup that you're already kind of happy with?
http://www.akaipro.com/lpd8
You could get something like this and use the pads to trigger hot cues and the knobs to activate effects like filters and flangers. And these are really cheap.
Also, check out the numark mixdeck if you fancy something with a bit more space and more controls
http://www.numark.com/mixdeck
geposted Sun 04 Apr 10 @ 4:10 am
The Denon HC-4500 is fantastic and fully mappable with VDJ and has a dual channel sound card built in. Not sure what the USA pricing is but it's well worth a look.
Keith
Keith
geposted Sun 04 Apr 10 @ 5:26 am
wow the NEWMARK thingy looks lovely... the first thing looks a little... "insubstantial"
Whats wrong with the RMX? too basic? even with the VDJPro software???
XXX
XXX
geposted Tue 06 Apr 10 @ 11:16 am
i love the rmx i use it for my dvs setup, check out my homepae for pics and details on my setup.
geposted Tue 06 Apr 10 @ 3:52 pm
Hi,
I'm kinda new to all of this and I'm looking probably for a second hand mixdeck or controller. I dont know which one it is that I want. I live in uk does anyone know of where I buy one from?
Broken spindle would love to buy your one off you, however I'm guessing you live in usa.
geposted Thu 08 Apr 10 @ 2:50 am
Have you looked into the Numark Mixdeck. Check it out dude.
geposted Thu 08 Apr 10 @ 11:56 am
yea, i don't mean to sound like i hate the hercules. I've had my eye on the Vestax VCI-300 because I recently realized I'll have more money. I think it looks like a good next step up. Who knows though. I might stick with the RMX I have for awhile until I can afford a full professional Pioneer set. The VCI-300 jog wheels are really what has my eye. The RMX jog wheels is probably what I dislike the most about the controller to be honest. They are tiny and feel unnatural. And yes, I do have Virtual DJ Pro. Have had a few friends tell me to try out Trakktor but, I don't know. We'll see.
geposted Fri 09 Apr 10 @ 3:51 pm
I have the Hercules RMX and do want to upgrade so I plan to upgrade to a Numark NS7 next month. I was thinking of still keeping the RMX for smaller venues. I've been having bigger gigs lately so I feel I need to upgrade.
geposted Fri 09 Apr 10 @ 4:40 pm
Well, you boys go off and get you bigger and better toys... i'm sticking with my lovely (small but perfectly formed RMX)
... although, that newmark thingy does look LLLooovvveeelllyyy!!! all the preddy lights an all...and the pressy buttons...
...and the twiddly knobs...OH THE TWIDDLY KNOBS!!!!
XXX
XXX
geposted Fri 09 Apr 10 @ 5:14 pm
