About a month ago, my cue points started having problems. For some reason, when I load a song that has a saved cue point, the wave form around the cue point disappears. Also, the audio gets chopped up for the first couple seconds. To fix it I have to set a cue point well before where I want to start, reload the song, and then reset the cue point that I want. This is extremely annoying because it happens the most with the songs I play regularly. I have since upgraded to 6.0.7 and the problem persists. Can someone please tell me how to fix this?
geposted Sun 04 Apr 10 @ 11:02 am
atomix guys... any idea what this can be it's really a pain in the a**
geposted Fri 09 Apr 10 @ 8:02 pm
Are you attempting to jump directly to a cue point in the middle of the track before the waveform is finished loading?
geposted Fri 09 Apr 10 @ 9:44 pm
No, it's before I even touch anything. I load the song and the waveform begins to load. When the waveform finishes loading, the waveform around the initial cue point disappears. Sometimes I play the first couple seconds and sometimes I can't.
geposted Sat 10 Apr 10 @ 6:34 pm
