I just notice they have cencore feature.
How about virtualdj?
geposted Sun 04 Apr 10 @ 11:51 am
The Subjected Should Be Spelled Serato ITCH.
geposted Sun 04 Apr 10 @ 11:52 am
Fixed ;-)
geposted Sun 04 Apr 10 @ 12:17 pm
cencore feature?
What is this?
What is this?
geposted Sun 04 Apr 10 @ 1:14 pm
VDJ already has this which can be enabled in the keyboard shortcuts.
geposted Sun 04 Apr 10 @ 1:19 pm
Yes, VirtualDJ has a 'censored' feature - it's called 'Bleep' ... can be assigned to a keyboard button or controller button. It plays the track in reverse for as long as it is active then returns to the original position of time if the action would not of been activated.
So if you activate the effect at 2:00 minutes and keep it active for 3 seconds. Then when released it will jump to 2:03 - censoring the 3 sec gap.
geposted Sun 04 Apr 10 @ 1:59 pm
is there a button on the factory skin for it?
geposted Sun 04 Apr 10 @ 8:38 pm
No
geposted Sun 04 Apr 10 @ 9:18 pm
u just haveta assign to it?
geposted Sun 04 Apr 10 @ 11:40 pm
Actually the VDJScript actions is called 'dump' ... just assign it to a button on your keyboard or controller ... this is the common script command -> dump while_pressed
geposted Mon 05 Apr 10 @ 11:46 am
sweet, will look into it, thanks man
geposted Mon 05 Apr 10 @ 4:39 pm
