If I get an RMX console, how much of a price break do I get on upgrading to the pro version?
geposted Sun 04 Apr 10 @ 2:04 pm
if you purchase the rmx, you would get a 50% discount to upgrade to pro, thats what i did...
geposted Sun 04 Apr 10 @ 5:24 pm
how much it cost??? I have RMX now
geposted Sun 04 Apr 10 @ 6:34 pm
If you go to the top of the page and hit the Buy tab and follow the instructions it will show you the amount you will save.
geposted Sun 04 Apr 10 @ 7:07 pm
So I will save $150, cool!
geposted Sun 04 Apr 10 @ 7:42 pm
its definitely worth it
geposted Sun 04 Apr 10 @ 8:37 pm
Guyszz, anybody know with the purchase of Hercules Deejay Trim 4&6 that comes with VDJ 6LE TC; whats the discount to upgrade to VDJ Pro? How much exactly?
ps: I hav nt purchased the audio interface thus pls dun ask me to refer to "Buy" and enter the serial no to see hw much for upgrade. Currently deciding between the Hercules Deejay Trim & NI Audio 4 DJ.
geposted Sun 11 Apr 10 @ 12:43 pm
No one knows???
geposted Mon 12 Apr 10 @ 6:25 am
Enter the serial number that came with your trim against your VDJ profile. Then go to the BUY tab at the top and you will be told the discount you will expect.
Cheers,
Roy
Cheers,
Roy
geposted Mon 12 Apr 10 @ 6:55 am
why not just go the whole hog and get an RMX that trim thing looks a bit basic and totally, not as much fun!!!
XXX
XXX
geposted Mon 12 Apr 10 @ 7:29 am
Hi seana, you're wrong;)
The trim is definately better than the rmx but of course rmx does have advantage as it can add as midi mixer too but quality it is not different as the mk2;)
one more good thing about the trim it have vu meter on them;)
regards.
regards.
geposted Mon 12 Apr 10 @ 1:50 pm
GadgetMan, pls refer to my post as said I hav not purchase the trim, so hw to enter serial no??? I dun need a additonal controller RMX as I already have my existing decks & mixer.
What I need to know is if I purchased Deejay Trim that comes bundled with the VDJ 6LE TC, how much do I have to pay to upgrade to VDJ Pro. This will affect my decision purchase of which model to get. And seriously, the Deejay Trim as an audio interface device is not as bad as you think; try it ;)
Anyone? A simple qn like ain't that hard to answer rite, sent a similar query to VDJ support till now still no response :(
geposted Tue 13 Apr 10 @ 12:53 am
KRYscs3, i knew a guy who has done the Upgrade from Trim to PRO.
If my calculate from Euro to Dollar is OK, it is round about 150$
geposted Tue 13 Apr 10 @ 8:02 am
Many thanks Haui70 :) You are quite rite, juz rcv a msg from VDJ support which they say is 149. Will be proceeding with my purchase afterall, can't wait to get my hands on it ;p
geposted Tue 13 Apr 10 @ 9:15 am
i always thought you got pro free with the rmx??
geposted Tue 13 Apr 10 @ 9:31 am
haha naah man, u ge the vdj rmx version, which is an LE version with it
geposted Tue 13 Apr 10 @ 9:32 am
