whats up fam, Im wonderin how do I reinstall my version of VDJ that I paid for? My computer was in the shop with a virus and when i got it back yearnin to put in some work I realized it not on here......HELP.... I need my musical fix
geposted Sun 04 Apr 10 @ 10:36 pm
I went to the download center reinstalled VDJ but when I tried to open it I get nothin. I get redirected to the internet to try and find a program to open it. Its like its just a read only file.....WTH UGGGGGGGGG
geposted Sun 04 Apr 10 @ 11:32 pm
hi, sorry to hear about your problem.
if you have the VDJ.exe just reinstall it, maybe run the registry cleaner first, this can be found in the downloads section.
If you need to re-download the program after logging in hear go to your download center and download a fresh copy, also if you forget your serial key its there too ;).
If you suspect anyone has gotten unauthorized info relating to vdj, or if you have any problems, contact support.
geposted Mon 05 Apr 10 @ 12:35 am
sounds like they wiped your drive clean, and if they haven't done it for you you will have to re install all of your drivers and codecs.
geposted Mon 05 Apr 10 @ 12:36 am
OK misread your original post I see you've already done that.
What Os are you using as with xp you can install VDJ after installing OS and basic MB Drivers (sound, Video) etc....
if your computer does not recognize the .exe then possibly OS is corrupted, try reinstalling OS , MB drivers, VDJ.
I'm not an expert .... so I hope that helps, Also some hacked or should I say custom versions of windows may not work correctly, ive tryed!
geposted Mon 05 Apr 10 @ 12:46 am
HA HAHAHAHA LOL LLS YES YES!!!!!!!! thanks u very much for everyones help.! I downloaded .exe file & BANG!BOOM!BOOOOOYA!!!!
geposted Mon 05 Apr 10 @ 3:49 pm
