When i start my Virtual Dj version 5 and i go to settings then to the list with all the devices i click the picture of hercules dj console to connect with my Hercules Dj Console MP3 and it lights up in red and doesn't connect
geposted Mon 05 Apr 10 @ 10:20 am
Try A New USB Or Update Your RMX
geposted Mon 05 Apr 10 @ 5:15 pm
Your VirtualDJ DJConsole version is 3.4.1 and not 5.x or even 6.x if you want to use another version, you can use it but have to upgrade to VirtualDJ Pro to work with your console.
Actually DJConsole Mk2 and DJControl MP3 can work without a problem with VirtualDJ Pro 6.0.7 in MAC OS and in Windows (XP, Vista, Windows 7 32 and 64 bits)
geposted Tue 06 Apr 10 @ 1:48 am
No I have V3 and also V5 and V6 i'm sure its V5 and it doesn't work...
In V6 i don't even have the list with the devices
geposted Tue 06 Apr 10 @ 3:51 am
