Has this happened to you?
No matter what I do, I cannot delete his music folder.
Even tried out the command line
del /f *
but it didn't work.
any help is appreciated.
and yes, this is a sub directory of my music folder on my dedicated 4.0tera hdd of nothing but mp3's. I have 2 folders that can't get renamed or deleted.
del /f *
but it didn't work.
geposted Tue 06 Apr 10 @ 4:10 pm
Which OS are you on?
Windows 7 can be a bit funny about permissions.
geposted Tue 06 Apr 10 @ 4:14 pm
If it's not the last one on the tree it won't delete, you need to drag the last folder up to the parent folder or above the one you want to remove, then you could delete.
Joey....
Joey....
geposted Tue 06 Apr 10 @ 6:39 pm
windows 7 ultimate 64bit
it won't move, it wont delete
never mind. i got it
command line: "del/f/q/s"
command line: "rmdir/q/s"
some files would be deleted through windows and not cmd. others would be deleted through cmd and not windows.. weird
thanks for all the help though
topic closed
DJ KZ
topic closed
DJ KZ
geposted Wed 07 Apr 10 @ 1:43 pm
