what would i need to use and do?
looking to use my netbook with VD and control it with a mixer. what equipment will I need and what would I need to change the settings to in VD
thanks
thanks
geposted Wed 07 Apr 10 @ 9:23 am
you need an external mixer, leads and a soundcard that will allow you to connect to your computer.
it is possible to connect a mixer up i believe, if you have a 5:1 surround card.( dont hold me to that) but most people use either a seperate card or a herc console.
see here for more
https://virtualdj.com/forums/105246/Hardware_Technical_Support/External_Mixer_Setup_with_PC_Speakers.html
see here for more
geposted Wed 07 Apr 10 @ 9:30 am
so I would need to connect the laptop to an audio device, then connect that to the mixer. so 1 cable going from laptop to audio interface. then 4 cables going from interface to mixer. 2 into 1 channel and 2 into the other channel?
geposted Wed 07 Apr 10 @ 9:37 am
