Forum: VirtualDJ Skins
Topic: Pioneer MEP - 7000 Controller Skin
Could someone make a skin for the Pioneer MEP-7000 Controller ?
Thank You
geposted Wed 07 Apr 10 @ 10:28 am
I could give it a try in a week or so as soon as I finish the current skin I'm working on right now. What type of Dj use you want it for? Audio? Video? Scratch?
I use The MEP-7000 for audio use only.
Thanks
FOR NEW UPDATE:
TODO MIX------> \"SKINATOR\"
The MEP-7000 skin looks great, I am excited about this , just waiting ti try it out
Thanks
Oswald Bobb
Any good news on the MEP-7000 skin?
Oswald
this skin look offical like it
Need a tester?? I run VDJ on Touchscreen and want to try this to see if the buttons are big enough... This skin looks badass, I also edited some of the BS posts out of your topic. B
already posted on the network, just need to stop the tests and for their respective downloads. is two resolutions 1280x800 and 1280x1024 I hope you like them. and if they like it, leave your worries. ok
Todo Mix ----------> Skinarte "skinator"
ps: I want to be tester skins !!!!!
be possible? I have to do to be tester skins? what level should I have?
vip? / Ultra vip / ......??
I think you just have to contact the person making the skin and ask them and I guess pro level and above.
Keith
Thank You Very Much, Great Job
Oswald
