Hi all
I have a Macbook pro running Virtual DJ 6, Numark Total Control and the Numark DJio (latest Driver)
i can get sound out of the soundcard, but i get either the first deck through Ex speakers and the second deck through headphones.
I want to be able to monitor the next track on headphones and play both decks to EX speakers.
Can anyone help or has this already been covered.
Thanks
Thanks
geposted Wed 07 Apr 10 @ 12:05 pm
For Sound Setup, configure as follow:
- Input : None
- Output(s): Headphone > Master Chan1/2 / headphone Chan3/4
-Soundcard: DJ IO (or USB audio, depending how it is detected)
- Input : None
geposted Thu 08 Apr 10 @ 6:05 am
Thanks for your help DJ Phatso
In the SoundCard section theres 3 options
1. separated audio - I have option for built in or USB Audio Device
2. 2 cards - 2 drop downs (when i select one built-in and the other usb device i dont get any sound from the DJ io
3. 4-out card - I have option for built in or USB Audio Device
which one do I select...
Thanks again for your help
geposted Fri 09 Apr 10 @ 1:24 pm
Hello jaxxienav,
In the SoundCard section, select the option
4-out card - USB Audio Device
geposted Thu 15 Apr 10 @ 7:40 am
