hi i keep gettin >SetupDLL\SetupDLL.cpp (462)
PAPP: Hercules Dj Console Driver
PVENDOR:Hercules (http://www.hercules.com)
PGUID:7A649F27-1A7B-42B1-8668-3BC2DD590919
$9.1.0.429
@Windows XP Service Pack 2 (2600) IE 7.6000.17023
Is there any easy way 2 remove this its not lettin me put a new software on or anything really doion my head in
$9.1.0.429
geposted Thu 08 Apr 10 @ 9:37 am
This probleme is due to an issue with some INSTALLSHIELD files.
Apply the following procedure to solve the problem:
- In the root directory or your main hard drive (usually C:), under the file <Program Files>, find the folder called <Installshield Installation information> (it's possible that it might be invisible so change your folder visibility properties to allow to view all files).
- In this folder, you'll find many subfolder archives related to software installed on your computer. One of them is related to the DJ console driver.
- For each folder, you'll find a file called <SETUP.INI>. Open this file to find the name of the program it's related to (ex; APPname= xxx).
- Find all instances related to the DJ Console driver and remove them from the computer (make sure they are not present in the recycle bin)
This should allow you install the drivers afterward. Use the latest driver available (4.HDJS.2009):
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=143&cid=1
geposted Thu 08 Apr 10 @ 9:46 am
i cant find this <Installshield Installation information>
geposted Thu 08 Apr 10 @ 9:50 am
As I said, you may need to change the file visibility properties
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/hiddenfiles.mspx
geposted Thu 08 Apr 10 @ 12:54 pm
i think i will format my comp will be easier lol sorry 2 bother u but thanks
geposted Thu 08 Apr 10 @ 8:34 pm
