Can someone please tell me how to change the folder that the slide show draws from?
geposted Fri 09 Apr 10 @ 8:48 am
start the slideshow plugin, go to the open tab, look for a new folder you want to use, double click on an image inside the folder, it will now start using all the images in that folder.
geposted Fri 09 Apr 10 @ 9:10 am
Thanks
geposted Fri 09 Apr 10 @ 3:24 pm
no probs. combine that with Firetext and you get a hell of an effect.
geposted Fri 09 Apr 10 @ 3:39 pm
Ok, I just came across this thread, and I must ask....where or what is the slide show plug-in? Thanks.
Dodie
Dodie
geposted Sat 10 Apr 10 @ 5:15 pm
There are two similar plugins that you can download one can be found on a multi use/purpose plugin "Firetext VDJ" and the other called "slideshow" both are free and you can get them here.. downloads > plugins > video effects.
Set up images for weddings etc or use them to display logos or adverts of various numbers.
If you need any help understanding the Firetext multiple purpose plugin give me a shout.
geposted Sat 10 Apr 10 @ 6:14 pm
