In the video effects, there is the "Text" effect.
I want to change this font. Is it possible?
geposted Sat 10 Apr 10 @ 8:00 pm
Which one are you using there are three, Firetext, Djcels Text2D and Sbdj Scroll text and all can have their font and colour set up changed.
geposted Sun 11 Apr 10 @ 4:16 am
Seems to me he's using the built-int "Text" effect ;) I don't believe you can change the font. You are much better off using one of the above mentioned plugins if you need anything more than Text provides.
geposted Sun 11 Apr 10 @ 5:13 am
ooops thanks Scott forgot all about that one.
@poopy pants, also forgot to mention using combinations of the above three effects will also give a stunning display on screen.
geposted Sun 11 Apr 10 @ 6:02 am
