What Laptop do you guys use for ur software..
geposted Sat 10 Apr 10 @ 10:58 pm
a cheeky macbook pro.
geposted Sat 10 Apr 10 @ 11:42 pm
Asus G51-RX05
geposted Sat 10 Apr 10 @ 11:49 pm
I HAVE BEEN BREAKING MY NECK TRYIN TO GET RITE 1
geposted Sat 10 Apr 10 @ 11:56 pm
HP G70, used it for over 14 months now, play 95% video.
geposted Sun 11 Apr 10 @ 3:38 am
I use a Packard Bell Easynote TJ65, I use mainly video
geposted Sun 11 Apr 10 @ 5:32 am
I previously used 13" MacBook, now I'm using 15" MacBook Pro (2.53GHz Intel Core 2 Duo, 4Gb 1067MHz DDR3 RAM).
geposted Sun 11 Apr 10 @ 6:26 am
i use HP Pavilion
geposted Sun 11 Apr 10 @ 7:05 am
Toshiba Satellite for the last 2 years. Also just picked up an
Acer Aspire.
Acer Aspire.
geposted Sun 11 Apr 10 @ 8:50 am
I used to use a Sony Vaio with a P4 chip (yes I know old), now I use an Asus G1S,http://www.notebookreview.com/default.asp?newsID=3728&review=Asus+G1S, and havent had any issues.
geposted Sun 11 Apr 10 @ 9:21 am
Im using a Macbook pro 15.4 screen 2.4 ghz Core 2 duo with 4 gigs of ram & 320 gig Hd
geposted Sun 11 Apr 10 @ 11:19 am
i found a macbook 13.3 is not a pro or air reg macbook for 799.99 usd new 1 yr warranty
geposted Sun 11 Apr 10 @ 11:25 am
Tryin to stay under 700.00usd if i Can
geposted Sun 11 Apr 10 @ 11:32 am
DELL LATITUDE D630... £200 SECOND HAND...LOVLEY!
xxx
xxx
geposted Sun 11 Apr 10 @ 11:49 am
Seconded.......
geposted Sun 11 Apr 10 @ 12:03 pm
Many Djs use laptops for only mixing Mp3's and others use one for Mixing Mp3's and music videos. For the NS7.. You need to look at this..
Macintosh
•Mac OS 10.4.11 or higher (including Snow Leopard)
•32-bit - Intel processor, 1.8GHz Core Duo; 1GB RAM
•64-bit - Intel processor, 2.4GHz Core Duo; 4GB RAM
•2GB RAM
•1024 x 768 screen resolution
•Available USB 2.0 port
•Available Hard disk space for music
Windows
•32-bit Windows 7, Vista, or XP
◦32-bit requirements: 1.8GHz Core 2 Duo processor; 2MB L2 cache; 2GB RAM(Win Vista), 1GB RAM(XP)
•64-bit Windows Vista
◦64-bit requirements: 2.2Ghz Core 2 Duo processor; 2MB L2 cache; 4GB RAM
Note: Beta drivers are now available for the NS7 which offer unofficial support for 64-bit versions of Windows 7. We recommend a minimum 2.4GHz Core 2 Duo processor; 3MB L2 cache; 4GB RAM for 64-bit operation. You can always find the latest drivers for the NS7 here.
To buy a laptop a " new " laptop that has above the minimum form what is listed here, You will have to spend about 700 bucks maybe more. If you look above, you will notcie XP uses less resources.. You can buy a 400-500 dollar laptop that comes with Windows 7 and Uninstall the OS and add windows XP pro 32 bit. The OS is around 50-80 bucks. Now you will be above the minimum because XP requires less resources than any other other OS. Look at this. http://www.microcenter.com/single_product_results.phtml?product_id=0325764
This is up to you if you want to spend less and have something above the minimum the of what is listed.
Macintosh
•2GB RAM
Windows
geposted Sun 11 Apr 10 @ 12:38 pm
lenovo n200 3000 with windows ultimate 7 for music and sometimes video use
sony vaio vgn/ns11m for music use with xp pro sp3
both run smoothly with vdj
geposted Sun 11 Apr 10 @ 4:44 pm
I have a Sony Vaio. Duo Core, 3 gigs of RAM, running VISTA. I play audio only. I would only recommend a Vaio and VISTA to someone who is experienced enough to get rid of all the bloatware. Other than that, it runs fine.
geposted Sun 11 Apr 10 @ 4:49 pm
I own several but only use two for gigs and one as a back up or for DMX & Ableton.
1. MacBook Pro 5.3 Snow Leopard (3 weeks old)
2.Toshiba Qosmio X305 Q708 Vista Ultimate 64 (1 year old)
3. Dell XPS Studio 17 Vista 64 (6 months old)
DJ RuDe
DJ RuDe
geposted Sun 11 Apr 10 @ 5:37 pm
IMPORTANT
ALL of you said the laptop ure using BUT if They work at FULL VIDEO MIXing?? and if they ARE WORKING FINE?
Im frustated I dont care how much I pay I m tired of buying laptops wasting money like stupid no matter how big is the system I have bad lukkk buying the wrong one, virtual should ADVISE that " not all LAPS gonna guarantee to work at FULL VIDEomix"
At full Video mix plus clipbank.
asus16" G60 VX cuda nvidia 1 gb dualcore 2.13 4 ram etc sucksss video freez programfreez 1000dlls to trash
gateway17' nvidia 9800 gt 4 ram etc dualcore 2.2 suckssss video slow freezz. automix sucks buzzz. 1000dlls to trash
UNTILL I WAIT FOR A SOLUTION I had scarry nights at the club and horroble quinceanera I had to play with 50 dlls mp3player to save those nights. and just play without video.
Tell me please WHAT LAPTOP WORKS with Virtual dj 6.07 To MIX VIDEOS all NIGTH. FOR me to BUY ONE. PLEASEE!!!!
geposted Sun 11 Apr 10 @ 6:26 pm
