My CPU usage is very low. I am trying to increase my Video load speeds. I have 4 gigs of ram. Thinking of upgrading to 8 gigs. Can someone comments on their thoughts or experiences.
Win 7
4 Gigs DDR3 1333
i7
Thanks.
Win 7
4 Gigs DDR3 1333
i7
Thanks.
geposted Sun 11 Apr 10 @ 8:17 pm
You will get no enhancement of performance just incrising the amount of RAM; secondly 4 GB are more than enough to handle videos.
geposted Mon 12 Apr 10 @ 2:44 am
What drive are the videos stored on and how is it connected to your computer?
geposted Mon 12 Apr 10 @ 9:33 am
how long does it take to load a video now?
geposted Mon 12 Apr 10 @ 10:32 am
They are on a 1tb external drive connected via eSata.
Rotational Speed (rpm) : 7200 rpm
Cache : 16MB or greater
geposted Mon 12 Apr 10 @ 11:04 am
i will time the load speeds and post an average this afternoon. Thanks.
geposted Mon 12 Apr 10 @ 11:07 am
It doesnt need to be "timed", a guesstimate would be fine VS the size and type of file.
geposted Mon 12 Apr 10 @ 2:23 pm
Try hooking up the drive to firewire and see the result or USB2 and take notes, may the best connection win!!!
Joey...
geposted Mon 12 Apr 10 @ 5:03 pm
a 57 MB MP4 (3:48) file takes about 15s while no other track is playing.
geposted Mon 12 Apr 10 @ 6:36 pm
Files have been pre-scanned?
If you move the same file to the internal hard drive, THEN load into VDJ, how long does it take ?
geposted Mon 12 Apr 10 @ 6:49 pm
eSATA is superior to both USB2 and FW800 for drive connections.
geposted Tue 13 Apr 10 @ 7:29 am
Yes, but I've heard of some people having an issues with this connection and then getting better results from the other, go figure...
Joey...
Joey...
geposted Tue 13 Apr 10 @ 11:59 am
Hi
My video files load times are about 1 second for each deck using vob files (av 300Meg)
I noticed the video speed really increased when I added my Nvidia sparkel Dual 7950GTS Video card 1Gig Ram
Though I am running also an Intel I7 2.8ghz 4gigs DDR3 etc,
But the video loads real quick, just need to get over the glitch playback of my vobs
Regards
Regards
geposted Tue 13 Apr 10 @ 1:39 pm
Load times are virtualy identicall..
geposted Thu 15 Apr 10 @ 8:32 pm
johnnysh wrote :
Hi
Regards
Regards
Are you on a custum bulid PC?
geposted Thu 15 Apr 10 @ 8:34 pm
They load a second or two faster.
geposted Thu 15 Apr 10 @ 8:37 pm
Joey...
Joey...
I actually had an eSata drive that I could not write files larger than 50MB or it would unmount then spin back up. I could however read files all day long. Eventually it got repaird by the manufacturer.
In my opinion don't cheap out with a eSata drives.
geposted Thu 15 Apr 10 @ 8:41 pm
Not my style, I just don't have one on my show rig, but my ext. drive has it..
Joey....
Joey....
geposted Thu 15 Apr 10 @ 9:01 pm
