Hey all, I just recently got VDJ and am running it on a mac OSX 10.5.8, with a vestax VMC-002XLu mixer. After getting it set up the first time, it ran totally fine for about a week. Every time it would boot it would tell me that the display resolution was different than the skin resolution, but clicking ok made it load fine. starting today, however, I clicked okay for the difference in display resolution but instead of loading as normal, the program crashed. trying to restart my system made no difference, except now I dont get any prompt telling me that the resolution is different, it just crashes once it gets to loading skins. This is the error report apple gives me after each crash:
Process: virtualdj [238]
Path: /Applications/virtualdj.app/Contents/MacOS/virtualdj
Identifier: com.atomixproductions.virtualdjpro
Version: ??? (6.0.1)
Code Type: X86 (Native)
Parent Process: launchd [79]
I havent changed any settings or installed anything recently, in fact I havent even touched my computer between djing sessions. Any clues? thanks
geposted Mon 12 Apr 10 @ 9:46 pm
Just download the last trial version because you are using an old version (6.0.1)
geposted Tue 13 Apr 10 @ 2:11 pm
