I cant hear the music that playin live through my sound card earphones, am I missin something? Help Please
geposted Tue 13 Apr 10 @ 9:43 pm
has this problem ever been solved?
geposted Wed 14 Apr 10 @ 11:49 am
More details about what soundcard ,headphone and configuration you are using would certainly be helpfull...
geposted Wed 14 Apr 10 @ 2:49 pm
ok, my sound card is a audio Kontrol 1, output for headphones/speakers (master 1st card - headphones 2nd) are my configurations. Im gettin live music in my earphones until go to cue another song. On the last version i was using (5.0) earphone volume was up in the left hand corner.
geposted Thu 15 Apr 10 @ 4:42 pm
change your skin or create some shortcuts.
you can disable the auto headphone switching.
geposted Thu 15 Apr 10 @ 5:55 pm
have you got a "Monitor" dial or button? is it switched to "Mix" mode? I have a dial that i can turn to either review the mix i'm doing OR the track thats just been Cue'd... on "Mix" i can hear both tracks while on "Cue" i only hear the side that have been Cue'd.
XXX
XXX
geposted Fri 16 Apr 10 @ 5:50 am
