I have been trying to figure out what is causing latency when I run videos. I run the latency checker and it goes into the red at 400+ when I run videos. I took off the hardware acceleration in VDJ and then latency checker shows no problem. Some features do not run with hardware acceleration off so how do I fix the DPC latency checker from not going in to the red when running videos?
I am using Geforce 8800M GTX video card.
geposted Wed 14 Apr 10 @ 12:07 am
sorry 4000+ in the red zone
geposted Wed 14 Apr 10 @ 12:17 am
I have disabled all internet , wifi etc....
geposted Wed 14 Apr 10 @ 1:19 am
what os are you running?
geposted Wed 14 Apr 10 @ 7:07 am
What are your computer specs? and do they meet the minimum recommended specs for running video?
geposted Wed 14 Apr 10 @ 11:05 am
Yes they meet the min. requirements.
geposted Wed 14 Apr 10 @ 11:10 am
I am using Windows XP
sorry, I should have been clearer..
do they meet the RECOMMENDED specs for video mixing
The recommended configuration to mix video is:
Dual Core 2 GhZ CPU
ATI or nVidia video card w/256Mb of Dedicated DDR3 memory (dual output capable)
2048 MB RAM
geposted Wed 14 Apr 10 @ 11:29 am
What is your CPU usage like?
(I have never used the latency checker, so +4000 means nothing to me)
geposted Wed 14 Apr 10 @ 11:33 am
8 series nvidia won't work correctly on xp it needs at least dx10
geposted Wed 14 Apr 10 @ 11:37 am
