we turntables budget recommended by the Timecode, which model is correct?
geposted Wed 14 Apr 10 @ 9:36 am
I dont really understand what you wrote, but here goes, Buy Technic 1200 MK2's and use Serato timecodes.
Hope this helps
Huey
Hope this helps
Huey
geposted Wed 14 Apr 10 @ 10:35 am
depends on the budget.
Serato timecode are always a safe bet.
Budget Turntable: Stanton T-62
geposted Wed 14 Apr 10 @ 10:53 am
I would use my RMX for Timecode, tell me whether virtual dj, works well with the RMX timcode?
geposted Wed 14 Apr 10 @ 12:49 pm
I use my RMX as the soundcard for a dual TT timecode setup. It works for me even though my turntables are low end. The RMX functions as a mixer but its not the best for scratching, the crossfader isn't super responsive or sensative. If you are getting TT's anyways might as well try it out but for the best setup you are going to need another mixer and possibly a soundcard
geposted Wed 14 Apr 10 @ 1:38 pm
at least technics 1200 mkII. there are no shortcuts. buy cheap, buy twice...
geposted Wed 14 Apr 10 @ 2:20 pm
tnank you!!!
geposted Wed 14 Apr 10 @ 3:52 pm
i use 2 Numark TTX + Hercules RMX - Very good equipment :)
geposted Thu 15 Apr 10 @ 9:55 pm
"i use 2 Numark TTX + Hercules RMX - Very good equipment :)"
thats what i got and i love it, check out my profile for more info and pic on my equipment
geposted Tue 20 Apr 10 @ 6:26 pm
