I just got DJ Control Steel and I keep getting the "controller has not been detected" error message when ever I open VirtualDJ_djc, even after installing the drivers. Been looking it up online for a lil over an hour and still haven't found a solution. anyone? please?
geposted Thu 15 Apr 10 @ 1:52 am
Well,that might seems obvious, but is the Steel connected to the computer when you are trying to launch VDJ ?
You should start by registering your serial number and download the latest update for VDJ (v.5.2.2) as well as the latest driver for the DJ Steel (v1.77):
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=226&cid=1
You can also make sure that it is installed correctly, as described in this document:
http://ts.hercules.com/faqs/eng/her_eng_00365.pdf
geposted Thu 15 Apr 10 @ 6:20 am
Hello,
Sometimes, uninstalling a version of VirtualDJ uninstalls also some ressources of DJ Control Steel (as VirtualDJ incorporates some ressources files of Hercules DJ Console series), so you should re-run the installation of Dj Control Steel drivers.
geposted Fri 16 Apr 10 @ 7:35 am
