http://i42.tinypic.com/14smsqr.jpg
As you can see from that image the top menu bar is completely cut off, i cant move the console or anything. I can right click the window and click move but it doesnt do anything. It's v6.0.5 full version and im on Windows Vista.
Some help please!
Some help please!
geposted Thu 15 Apr 10 @ 5:07 pm
Full version? You should register for greater support. Until then you could move the windows taskbar (right click on the taskbar, unmark 'lock the taskbar' then just drag it down)
geposted Thu 15 Apr 10 @ 5:34 pm
Thanks, that fixed it
geposted Thu 15 Apr 10 @ 6:10 pm
