Topic: hello just joined and need some help
my question is can i use the program on more then 1 machine. I own a laptop that i use for work but I do alot of organizing on my home pc.
geposted Thu 15 Apr 10 @ 9:05 pm
You sure can no probs at all, it's exactly what most of do. And welcome to the community.
isnt that a licensing violation?
That's what I would think....
Tayla can you expand on this further as I would like to know the answer to this just like the OP.
This is an extract from my VDJ pro EULA...
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
I'm not sure if this is different for trial or limited users, but think its the same.
Thanks for looking that up for all us that don't read the EULA. That's good information to know when I do end up purchasing a PRO license.
