My Hercules RMX works except it wont play the songs (it will let them load though). Also the jog wheel wont work. How do I fix this?
geposted Fri 16 Apr 10 @ 6:03 pm
Say Zaruru,
Check your sound card settings. Either on the RMX or your computer (which one are you using) Did you see an error when VDJ loaded? When the sound card doesn't load properly, your tracks will load, but nothing will play.
geposted Fri 16 Apr 10 @ 6:58 pm
