hi i'm jst starting out with becoming a dj and i have a few questions
1. i'm buying the DJLAB 2.1 Stanton that comes with 2x T.62 and a M.212 stanton mixer and wanted to know if i bought a Maya44 USB soundcard could that hook up my set up to virtual DJ?
2. i have 2 purple scratch live control vinyls will these work with virtual dj and my setup in the previous question and if they won't can i make them work or what's a solution
3. What's the real difference between timecoded vinyls and scratch live digital control vinyls
Thanks your help is really appreciated i really need to know
Regards Jak,
Regards Jak,
geposted Sat 17 Apr 10 @ 2:53 am
Regards Jak,
Regards Jak,
To answer your questions...
1. yes
2. yes, they will work
3. scratch live digital control vinyls ARE timecoded vinyls
geposted Sat 17 Apr 10 @ 7:45 am
thank you alot! that really helps,
i'm glad that works because i did just buy 2x scratch live control vinyls for my setup and now i've just bought my ESI - MAYA44 USB from austria to come to australia lol
thank you,
thank you,
geposted Mon 19 Apr 10 @ 3:47 pm
No problem, I use the Serato vinyls and they work great with VDJ. Just remember to make sure you click on the "debug" button in the timecode section of the config menu and select the correct side of the vinyl (A or B).
geposted Mon 19 Apr 10 @ 6:56 pm
thanks this really helps you have no idea lol thank you!!
one last question though would the ESI U46DJ USB AUDIO INTERNFACE SOUNDCARD work with the same setup as i have in my first question?!
geposted Thu 22 Apr 10 @ 2:42 am
No the ESI will not work on MAC OSX .. on OSX the only working Soundcards for Timecode:
Numark Virtual Vinyl Box, Hercules Trim
geposted Thu 22 Apr 10 @ 2:50 am
so there the only to sound cards that work? is there any USB mixer sound cards that will work? because i'm looking for something on the cheaper side that is available in australia?
geposted Thu 22 Apr 10 @ 3:12 am
for working with timecode on OSX there are @ moment no other soundcards that work ;)
geposted Thu 22 Apr 10 @ 3:25 am
Hercules rmx and Hercules mk2 work right from the box too. Not all soundcards work with timecode capabilities on mac side yet but you could try creating it as the aggregate device and see if it's work. But the known and reccomended ones are mentioned here.
geposted Fri 23 Apr 10 @ 7:17 pm
does anyone know if these work:
1. Reloop 10tion Soundcard
2 Behringer U Control UCA202 Audio Interface
3 Behringer U Control UCA202 Audio Interface
4. Native Instruments Audio 2 DJ Sound Card
I saw them on an online store that's close to where i live because it's taking months to get my Maya44 USB to australia
so does anyone think or know any of these work with my setup? most likey the "Reloop 10tion Souncard"
geposted Tue 25 May 10 @ 3:42 pm
