Does anyone know if its possible to run VDJ timecode using a mini laptop,is it powerful enough??
geposted Sat 17 Apr 10 @ 8:05 pm
Well depending on what mini-laptop your talkin about I would say go to there webpage and compare the specs with ,The minimum requirement to run Virtual DJ is:
PIII 850 MhZ computer
1024x768 SVGA video
DirectX compatible soundcard
512 MB RAM
20 MB free on the hard-drive
The recommended configuration is:
PIV 3 GhZ computer
1024x768 SVGA video
4.1 DirectX compatible soundcard (with front and rear separate outputs)
1024 MB RAM
200 MB free on the hard-drive
The recommended configuration to mix video is:
Dual Core 2 GhZ CPU
ATI or nVidia video card w/256Mb of Dedicated DDR3 memory (dual output capable)
2048 MB RAM
1024x768 SVGA video
512 MB RAM
PIV 3 GhZ computer
1024x768 SVGA video
1024 MB RAM
Dual Core 2 GhZ CPU
2048 MB RAM
geposted Sat 17 Apr 10 @ 10:29 pm
Cool bro thxx
geposted Sat 17 Apr 10 @ 11:48 pm
No problem.
geposted Sun 18 Apr 10 @ 4:25 am
I wouldn't recommend doing video. I tried with audio and did not have any issues.
geposted Sun 18 Apr 10 @ 11:51 am
what about ah solution 1024x600? do you have a VDJ for the mini notebook for the screen solution 1024x600?
i hope you have for that because i need that for my proj. and business.... thank you very much you read this
geposted Mon 18 Nov 13 @ 9:27 am
there is three netbook skins.
geposted Mon 18 Nov 13 @ 11:39 am
But you need to be a registered user to download them
I sometimes use one of the 1024x600 skins and it works fine but there's not much browser area unfortunately.
geposted Mon 18 Nov 13 @ 12:52 pm
