I am using Tag & Rename to delete comments. After I finish the comments are deleted
within Tag & Rename and saved accordingly.
However when I open VDJ the comments are still there.
Does anyone know why the comments would remain in VDJ even though tagging program has deleted them?
ALso the version I have is 3.4; WIll it work in windows 7?
geposted Sun 18 Apr 10 @ 1:05 pm
Because VDJ just reads the ID3 information when analysing a new song and the write the information to its internal Database.
You should select all the changed songs/folders and press the right button. Then reload the ID3 Tags with 'Reload tags'.
Greets, Heiko
Greets, Heiko
geposted Sun 18 Apr 10 @ 1:15 pm
Yep that's what I have done.
I tried Media Monkey, and followed the same steps.
That worked, can't understand why it did not work the
same in Tag & Rename.
Thanks
Thanks
geposted Mon 19 Apr 10 @ 7:29 am
if u have serato and vdj installed on the same laptop, do u know if one program deletes the comments written by the other?
geposted Tue 20 Apr 10 @ 6:21 pm
Only VDJ on system, nothing else.
Just noticed I was not clear when I said 3.4.
That references to tag & rename not VDJ.
VDJ version is 6.07.
geposted Wed 21 Apr 10 @ 9:29 am
The easiest thing would be to select all tracks in which you want to delete the comments in VDJ and then rightclick - remove comments.
Greets, Heiko
Greets, Heiko
geposted Wed 21 Apr 10 @ 9:34 am
