@cstoll
You are correct! Might help if i had the NUM LOCK on. Duh!!
Thanks for verifying that it works,
DJ James
DJ James
geposted Sun 02 May 10 @ 3:05 pm
Well, the HS5500 works much better than they did before, but I've still got issues. Whatever the selected deck is on the controller, the temp/pitch of the song flutter up and down. You can even hit the sync button and they'll match tempos, but still slip, though the slip seems to be consistent with whatever deck I have active on my controller. It seems like no matter what I do I cant get the beats to stay matched up, the active deck constantly falls behind the other one, even if i keep nudging the tempo/pitch slider to slow the deck down. It seems the only way i can keep the beats synced is by spam clicking the 'sync' button.
Hopefully its not my controller, i could try and just plug in my 2nd one. Last friday I ran with one for about the first 1.5 hours of the night, then I started getting some issues with VDJ not responding to my controller so I had to cue up an mp3 on my 2nd HS5500 and restart virtual DJ, I ran the rest of the night without the controller.
geposted Mon 03 May 10 @ 6:46 pm
does anyone know where I can download VDJ 6 I was told you can get it free is this true
geposted Tue 04 May 10 @ 12:10 pm
That seems to be a funny joke. You can get the trial version for free **lol**
But if you enter your LE serial number at the order page you get a discount when buying version 6 pro.
Greets, Heiko
Greets, Heiko
geposted Tue 04 May 10 @ 12:48 pm
Hello. how can I activate the mic on VDJ?
geposted Tue 04 May 10 @ 8:21 pm
The mic on what?
geposted Wed 05 May 10 @ 5:18 am
Hey everyone i just bought the 6.0.8 vdj so far so good take care and i will talk to you all soon.now i'm goin to practice
geposted Wed 05 May 10 @ 9:09 am
Hi,
Can I use this 6.0.8 if I am a RMX/LE user? The original post in this thread says its available to LE users, but when I click on my download centre, I only see version 5.2.2 available to me.
Am I doing something wrong?
Sorry for the noob question.
geposted Thu 06 May 10 @ 2:33 am
you can get a 50% discount since you have the LE version.Good Deal !! but not free...
geposted Sat 08 May 10 @ 9:23 pm
Hey.. Does the Mic work? Also, anyone know why the icon for the DMCs next to my list of goodies is really an icon for a Total control?
geposted Sun 09 May 10 @ 7:05 pm
Does the Mic on the NS7 work with the 6.0.8?
geposted Mon 10 May 10 @ 10:36 pm
I have upgraded to latest version but the effects no longer work ( Backspin Etc) Any ideas ??
geposted Tue 11 May 10 @ 10:11 am
No audio input changes have happened yet.
Quote :
VirtualDJ 6.0.8 (18 April 2010)
lower latency and better sound for motorized wheels (S3700, HS5500, NS7, V7)
fixed multi-deck issues with V7 and HS5500
fixed problems with netsearch video
added new controllers in the native list
new action motorwheel_instant_play
fixed potential bug in load/save windows' extension list
plugin_select actions can now be assigned on sliders
by default netsearch returns video results only if video is active
new registry entry: MotorScratchSmooth
send button-release on midi CC buttons
fixed ID3 tags with non-compliant encoding on localized versions of Window
geposted Tue 11 May 10 @ 11:00 am
thats a weird one!!
you might want to start a support ticket or ask in a new thread..
geposted Tue 11 May 10 @ 11:02 am
I thin the thing with microphone input of NS7 or other controllers takes it's time. Most of these controllers use an ASIO input channel. I think it's not only turning on a switch an mic is working.
This thing takes it's time to imlement, test and then when ready to be released. Good things takes there time....
Greets, Heiko
Greets, Heiko
geposted Tue 11 May 10 @ 11:04 am
Thats great that it takes time... but on that same note, I love my NS7, and I wouldnt trade it out for anything, but really, why should I have to run 2 mixers just so I can have a Mic with my NS7? I gotta feed my NS7 in to a small 2 channel mixer that has a mic input. that is kinda alot to do at gis, extra table space. If it works in Itch, that it could work in VDJ
geposted Tue 11 May 10 @ 11:52 am
The mic on the NS7 is not currently supported - It should be supported in a future version update of VirtualDJ.
geposted Tue 11 May 10 @ 12:33 pm
Thank you-
geposted Tue 11 May 10 @ 2:15 pm
how can i re-enter in vdj script the beat skip -1,that is on the cd version,into the updated version? in the updated version it's not there anymore!! i tryd to enter the cd version script into the updated script but it doesn't work!!
someone help me!!!!
thanks!
someone help me!!!!
thanks!
geposted Wed 12 May 10 @ 4:22 am
Use goto -1
geposted Wed 12 May 10 @ 12:37 pm
