Hello.. I have Virtual DJ 6.0.16 and I have a shoutcast server. The problem i am having is when i stream to the shoutcast server.. I streams fine.. i can listen from the vitual dj software and listen to the out going stream... when i listen on my laptop it start off well..but after some time.. it sounds as if there the song is playing double and out of sink with each other.....
Any Ideas.....?
Any Ideas.....?
geposted Mon 19 Apr 10 @ 12:59 pm
did you ever find an answer to this problem?
I can broadcast just fine with the virtual dj (byitself no shout or ice cast) and also with just winamp (using shoutcast) I can also use virtual dj and broadcast through winamp(using shoutcast)the problem is when I try to use virtual dj and shoutcast. After a few minutes I tend to get an echo that after about 20 min or so it more like the same song being played just a second or two later. now this is only when it's being broadcasted via shoutcast. On my end it sounds great. Can someone give me some insight on how I might be able to fix this? djraptor@yahoo.com
geposted Tue 11 May 10 @ 12:25 pm
