Hi,
I am currently using a Soubd Blaster Audigy 2 External card, its done me well for years but its seems like its on its way out.
Can anyone reccomend what sound card to get,
I do not use time code and use a vestax vci-100 if that makes any difference!
Chris
Chris
geposted Mon 19 Apr 10 @ 2:10 pm
I will without a doubt recommend the Audio 2 dj. I don't have this card but have the Audio 4 dj because of timecodes and heard the audio 2 dj is the same just without the inputs. Loud and clear with a high db output. Trust me even Ean Gold from dj tech tools recommends it. Native instruments all the way,extremely stable and rockkk solid.
geposted Mon 19 Apr 10 @ 10:22 pm
Upgrade to Vestax VCI-300. It will be like use your VCI-100 but with the external sound card, all in one. Good luck...
geposted Tue 20 Apr 10 @ 12:44 am
I have had a look at the reviews and the card seems class! Just bought myself a Audio 2 DJ, should be here ready to use for the weekend!
Wish i could afford the the vci-300 but its almost 500 quid
geposted Tue 20 Apr 10 @ 1:56 pm
good luck getting the Audio2 DJ working with VDJ, I tried for weeks to get it to work with no luck. Kept having audio dropouts and freeze ups and my laptop has plenty of horse power. Finally went back to using my old Behringer UCA-202 which works flawlessly with VDJ using Vistas native ASIO drivers.
geposted Tue 20 Apr 10 @ 5:19 pm
Thanks for the tip djvon, the audigy 2 dj has been running for 10 hours non stop no issues whatsoever, the sound quality is far better than all of the previous cards i have had!
geposted Thu 22 Apr 10 @ 12:25 pm
