I have been using the PCDJ VJ setup but due to lack of support I started messing with Virtual. The problem I am having is that I can't get the videos to automix from player a to player b when loaded in the playlist. Am I missing a setting or something. I want to be able to load the playlist and let it start playing without having to do anything. When I do this now it keeps loading the files into player a only. This is not optimal since you loose out on the transition effects and if there is a problem loading the file you don't get a heads up before hand.
geposted Tue 20 Apr 10 @ 12:18 am
The AutoMix feature only mixes on one Deck. It will mix on whichever deck is currently playing.
So if the left deck is playing and you automix, it will mix on the left deck. If you start playing on the right then enable automix, it will automix on the right deck.
geposted Tue 20 Apr 10 @ 12:28 am
Dual-deck automix was depreciated some time ago (Replaced with a more flexible single deck option), but it can be optionally enabled again by assigning a keyboard or MIDI shortcut to the action automix_dualdeck
geposted Tue 20 Apr 10 @ 1:29 pm
Thanks for that one ive just set that up as a keyboard shortcut
geposted Tue 20 Apr 10 @ 6:37 pm
Exactly what I wanted. I figured out how to do this in Ver.6 with your help but is it possible to add this to Ver. 5? I guess I need to upgrade since i also like the "Auto Removed Played" option found in Ver.6.
geposted Tue 20 Apr 10 @ 10:35 pm
You'll need to register your copy first before you can do that though, i would have thought.
geposted Wed 21 Apr 10 @ 4:50 am
