O.k. this is my issue, I'm running vdj latest version with RMX console and 2 turntables all on a PC. When I use the turntables The sound is being chopped up which gives me a bad timecode signal(jumps from 1-100% back and forth). Its the same when using real vinyl records. When mixing without turntables(rmx only) it sounds fine. It worked fine for the first week or so then all of a sudden giving me problems. I have re-installed vdj 3 times and updated drivers but still have the issue. I'm using serato version 2 timecodes, but I don't think that is the problem since I have the same problem with a real records. Anyone have any Idea what might be the problem?
geposted Tue 20 Apr 10 @ 10:57 am
latency settings/
geposted Tue 20 Apr 10 @ 6:27 pm
That was it, Thanks a bunch. I can't believe I didn't check that first, right in front of me. Thanks again.
geposted Wed 21 Apr 10 @ 11:07 am
