is there a way to use or have the serato soundcard apply to the crossfader of vj
cuz when i connect the serato everything works. but on the vj i have to have my crossfader in the middle is there a that the serato or the setup reconized when i crossfade on the mixer to the vj. jus like how a midi player would. ??
geposted Wed 21 Apr 10 @ 11:23 am
No, that is not possible.
The only way you can do this is with a MIDI capable mixer (Such as Pioneer DJM-700 or 800) that sends the position of its crossfader to the software, so that you can map it to act appropriately (E.g: To video_crossfader in VirtualDJ) or use a completely separate MIDI controller with a crossfader alongside your existing audio mixer.
geposted Wed 21 Apr 10 @ 3:59 pm
cool thnx i was jus curious to see if it was possible thnx
geposted Fri 23 Apr 10 @ 6:33 pm
Yes only be possible with an external mixer that has midi options, how to use the box with the serato vdj software is compatible but like an external card for audio.
geposted Fri 25 Jun 10 @ 9:29 pm
