I just looked at picking up the new Intel Core i7 MacBook Pro...The only video out is a a Mini DisplayPort....Can I use the Mac Mini DisplayPort to VGA adapter, then a VGA to S-Video adapter? If not, how do you run your video? Thanks.
geposted Wed 21 Apr 10 @ 5:37 pm
Either should work, I use both vga and svideo.
geposted Thu 22 Apr 10 @ 7:34 am
Why would you use Mini Display to VGA to S-Video when you can just get a mini DVI to video adapter?
click here... http://store.apple.com/us/product/M9267G/A?fnode=MTY1NDA3Ng&mco=MTA4NDU1Mjc
geposted Thu 22 Apr 10 @ 7:51 am
because the new macs don't have dvi connectors they are using display port.
geposted Thu 22 Apr 10 @ 9:06 am
I have same issue please help can i connect mini display to VGA then VGA to video & s-Video adapter.becoz on my Mac dont have mini dvi port it has hdmi output also but this output show me full screen virtual DJ ??
17-inch
2.2GHz Quad-Core Intel Core i7
4GB 1333 MHz DDR3 Memory
750GB hard drive
FaceTime HD Camera
Thunderbolt Port
SDXC card slot
Built-in 7-hour battery
Intel HD Graphics 3000 with 384MB
DDR3 SDRAM
AMD Radeon HD 6750M with 1GB GDDR5 memory
American Audio VMS-4
Thanks in advance..
17-inch
750GB hard drive
FaceTime HD Camera
Thunderbolt Port
SDXC card slot
DDR3 SDRAM
Thanks in advance..
geposted Thu 28 Jul 11 @ 11:40 am
17-inch
750GB hard drive
FaceTime HD Camera
Thunderbolt Port
SDXC card slot
DDR3 SDRAM
Thanks in advance..
17-inch
750GB hard drive
FaceTime HD Camera
Thunderbolt Port
SDXC card slot
DDR3 SDRAM
Thanks in advance..
geposted Thu 28 Jul 11 @ 11:42 am
using the mini display port.. there is an adapter available to any other connector. I use the VGA and HDMI adapters
geposted Thu 28 Jul 11 @ 7:09 pm
