hi...i just switch from a p.c. to a macbook now my denons s3500 is not working with the timecode....i'm using the serato sl 1 hardware...plz help doing party this saturday..and i'm stuck
thanks in advance
thanks in advance
geposted Thu 22 Apr 10 @ 7:16 pm
did you download drivers for mac to use with your hardware
geposted Fri 23 Apr 10 @ 4:48 am
I believe the sl1 doesn't work on the mac side yet.
geposted Fri 23 Apr 10 @ 7:17 am
so is there anything i could do to make it work
geposted Sat 01 May 10 @ 11:07 am
how do i do that?
geposted Sat 01 May 10 @ 11:08 am
Even if you download the drivers...The Serato box doesn't show up in a mac running virtual dj. You only see 4 in 4 out Card & Not SL 1 Box. Since you have a Mac. You can always bootcamp it and it will work.
geposted Mon 03 May 10 @ 10:52 pm
please explain to me how to get it working my son is losing intrest in spinning...he doesn't like using the serato
geposted Tue 04 May 10 @ 2:49 am
Use serato for now but untill then.....Your mac needs to be bootcamped. Every mac allows you to install windows for those that need to run windows based software. It sound technical but its easy to do. Your mac installs a partition into your hard drive and that partition is to install a copy of windows, what ever choice you want. XP, Vista Or Windows 7. I am using XP for just audio dj iing.
Instructions Here...http://manuals.info.apple.com/en/Boot_Camp_Install-Setup.pdf
geposted Wed 05 May 10 @ 12:18 am
Alternatively you could purchase a sound card that is compatible with VirtualDJ Mac, such as Hercules DJ Trim.
geposted Wed 05 May 10 @ 1:52 pm
I never thought about that JP.. @ F_Dip. You can always selll your serato box on craigslist. You will find a buyer quick trust me.. Once you sell it, you can buy the Hercules DJ trim.
geposted Wed 05 May 10 @ 5:23 pm
