Hi,
I have a weird issue, I had a hercules MK II which when I was using the knobs or the jog wheel on the controller I would get a distortion sound. I have recently changed my controller to the M-Audio Xponent but still have the same issue.
It might be worth adding that before purchasing the Xponent I built a new pc.
So I have changed the controller and all computer components in my computer but still have this issue.
Anyone else have these sort of problems?
Many thanks in advance.
Jay
Jay
geposted Fri 23 Apr 10 @ 7:26 am
It would be helpful if you would post your specs and settings. This way, there is sort of a jumping off point for the possible causes of your issue.
Offhand, I would usually suspect performance settings or latency issues.
geposted Sat 24 Apr 10 @ 7:25 pm
