My Computer specs:
Intel P4
Proc. Speed: 2.66 MHz.
RAM: 512 Mb.
Vdj uses between 89% and 100% of processor resources. Is that normal?
Thanks!
Monak
Intel P4
RAM: 512 Mb.
Thanks!
Monak
geposted Sat 24 Apr 10 @ 5:40 am
My old laptop had a P4 and it ran audio fine but I also had 2gig of ram. It would max out when a song was loaded but they say thats what happens. I couldnt run video, not even close. I would say up your ram and if the doesnt work buy a new lappy. I should ask are you using timecodes? I did and it worked fine.
geposted Sat 24 Apr 10 @ 6:34 am
Yes, that's normal for a single core processor and nothing to worry about.
512mb RAM is a bit tight though!
geposted Sat 24 Apr 10 @ 6:52 am
Also, some skins load Maiximized automatically. Try clicking the restore (Middle) button for screen size. Sometimes the maximized causes the cpu to show high usage.
geposted Sat 24 Apr 10 @ 11:19 am
Or just use an Skin that fits to the resolution of your screen.
cu
pOpY
cu
pOpY
geposted Sat 24 Apr 10 @ 12:34 pm
Probably yes with those system spec's.
If you are DJ'ing professionally, do yourself a favour a buy a new system.
geposted Sat 24 Apr 10 @ 1:16 pm
yeah like others said a P4 is kind of out dated. shit you can get an i3 laptop for around $400 usd for audio.
geposted Sun 25 Apr 10 @ 9:25 am
