hi,
quick question:
i use tccd and when there is about 15 sec left on the actual tccd it switches to internal mode and i cannot control my track from the cdj 1000... im sure this is some sort of warning but i want it off if possible.. how would i do this?
thnks
quick question:
thnks
geposted Sat 24 Apr 10 @ 7:46 pm
Maybe you could use another program and just loop the tone for 60 or 80mins then burn it. keep it on Absulote or Smart mode that way you always have to start from the beginning of the cd. I use timecoded vinly so I'm assuming it would work the same way.
Hope this helps
Huey
Hope this helps
Huey
geposted Sat 24 Apr 10 @ 8:47 pm
hmm thnks thats actually not too bad an idea... i guess it is just an mp3 file afterall ill loop in ableton.. i just thought it was a setting i cud turn off but i guess this wrks also.
although, not to belabor the issue but i also used to use tcv and u didnt have this problem. that is, u can still control the vinyl until ur needle hits the label..
its jus wierd that it does this
geposted Mon 26 Apr 10 @ 3:42 am
