Hey guys got the new virtual dj v6 and love it but i was wondering about a keyboard shortcut i cant seem to program i went into the settings and tried it but it wouldn't work. what im trying to do is when i have the song selected in my play list and i want it so i can pick which deck i want the song to go in like deck 1 or deck 2 but how would i set this up, i use to use serato and i like the fact that when you pressed shift+right or left that deck would load is there anyway i can do the same kind of setting in virtual dj v6 ?
thanks
thanks
geposted Sun 25 Apr 10 @ 11:33 am
try this, Deck 1 Load, mapped to whatever key you want say L for left (deck 1) and, Deck 2 Load, mapped to key R for the right deck (deck 2)
Hope this helps
Huey
Hope this helps
Huey
geposted Sun 25 Apr 10 @ 11:40 am
thanks so much it worked perfectly :)
geposted Sun 25 Apr 10 @ 2:10 pm
