Hey guys I just got a Korg Nanopad I was wondering if anyone who has this could tell me some good effects that are on the plugins download page that are good fro the touch pad, also I havent been able to get the touch pad working that well with the plug and play midi map already on VDJ. Thanks for the help!
Sorry if this is a double post most of the threads I found on the nanopad though werent in english and I couldnt read them
Thanks again
Thanks again
geposted Mon 26 Apr 10 @ 4:33 pm
Use the controller definition thats on the tools and drivers page, it works much better.
geposted Mon 26 Apr 10 @ 8:38 pm
you wont get the touch pad to work right. the language is different. i own one and have used it for a year as from what i have learned and read it won't work.
geposted Mon 26 Apr 10 @ 8:59 pm
Mine is working. I have control for X and Y axis in pad.
You need to modify some things at the Korg Editor.
Check my homepage
You will find a link for a setup file. (called me.file)
If you have the Black model download also the mapper (definition). I f not use the one included in VirtualDJ. Anyway it's not the mapper, it's the way NanoPad works. It has to do with the Korg Editor.
Check my homepage
geposted Tue 27 Apr 10 @ 12:23 pm
thanks guys!
geposted Thu 29 Apr 10 @ 4:46 am
hi djdad, where is your homepage with the korg file?
geposted Sat 10 Dec 11 @ 10:28 am
geposted Sat 10 Dec 11 @ 12:11 pm
