Something happened with the title...it was supposed to continue and say because "virtual dj crashes too much"
It all depends on your computer, settings, and the way you tweak your system....bottom line
There is no perfect application, program, or user. Too many variables to consider.
geposted Tue 27 Apr 10 @ 10:06 pm
You know whats funny. Ive seen djs with lime wire installed, Lots of extra useless software installed, The Wireless connection on, etc. Then they wonder why software crashes.
geposted Tue 27 Apr 10 @ 10:57 pm
The answer from ssl will be get a mac.
geposted Wed 28 Apr 10 @ 7:51 am
Just from my own experience, VDJ crashes on my mac as well, not often but sometimes after 4/5 hours of playing. Traktor Pro does not crash.
BCondemi
BCondemi
geposted Wed 28 Apr 10 @ 8:43 am
Check out the mac section on this site for help with that.
geposted Wed 28 Apr 10 @ 9:04 am
BCondemi
BCondemi
For some it will, for some it won't. Same thing with VDJ. Same thing with Serato!
geposted Wed 28 Apr 10 @ 12:36 pm
ok guys you had your fun I'm shutting this one off thanks for playing...
geposted Wed 28 Apr 10 @ 4:39 pm
