Did a search using "Virtual Folder" but no luck with information I'm searching.
Using an external hdd for music/vids, if I add a virtual folder "Pop" and add songs to it using cpu A will the Virtual Folder and all contents appear when I connect hdd to cpu B? Basically, where is the information saved?
(post made via iPhone thus no manual installed-hmm perhaps I sbould do that but how?)
geposted Wed 28 Apr 10 @ 5:31 pm
