Looking got get a pair. Pros...Cons....? If you use them as MIDI controllers, can you easily switch to using a regular CD if you have to? Also, when you do run a regular CD (not a timecode, etc.) can you still control that particular VDJ deck by using the keyboard, or is that deck out of commission until you re-instate the 3700's MIDI function?
geposted Wed 28 Apr 10 @ 10:42 pm
What Up Kizzle. I have the 3700's. I havent hooked them up thru USB but since i have the pair, i can try to do what you would like to know. Give me some time find out.
geposted Thu 29 Apr 10 @ 2:06 am
Read the hardware forums. A lot of feedback there.
geposted Thu 29 Apr 10 @ 6:12 am
Ok great. Thanks!
geposted Thu 29 Apr 10 @ 9:52 am
i run 4 3700's 2on cd 2 on midi on 6.05 seems to be the best so far , switching from midi to cd or usb is kind of slow and yes when you switch to the cd the player is pretty much out of commision also if you take it out of midi mode while using vdj it causes vdj to lockup. still some little querks to work out but it def seems like they are working on it
Todd Dion
Port City Productions & Entertainment
djxtreme30@gmail.com
facebook- todd dion
facebook-dj Xtreme
myspace- djxtremenc
yahoo-djxtremenc26
google-djxtreme30
Todd Dion
facebook- todd dion
facebook-dj Xtreme
myspace- djxtremenc
yahoo-djxtremenc26
google-djxtreme30
geposted Fri 30 Apr 10 @ 12:13 am
