I am trying to setup the timecode, but I can not find which vinyl option to use with this signal. There's no Numark vinyl option at timecode engine and Numark virtual vinyl manual dont shows wich signal to use.
The timecode signal seems like noisemap, but serato CV02-A e CV02-B dont works fine.
One video at youtube leads to VirtualDJ v5 signal.
geposted Thu 29 Apr 10 @ 1:09 am
Hello they are the same records as Virtual DJ's timecode signal choose the latest Virtual DJ engine.
geposted Thu 29 Apr 10 @ 7:47 am
Thanks
geposted Thu 29 Apr 10 @ 9:33 am
Just a feedback.
We have done every timecoding signal debug combination (using VirtualDJ Vinyl, VirtualDJ vinyl old engine v4 and VirtualDJ vinyl very old engine v3 and debugs invert stereo, invert phase, RIAA filter, LP filter, celarsound) but could not reach 100% fidelity.
We try at least 100 combinations.
Even at 0% the system works fine, but 100% we cant find.
With VirtualDJ 5.0.7 we could reach 100%.
Anyway, we stopped and the setup owner decided to sale the card and the Numark vinyls and try Serato.
geposted Thu 29 Apr 10 @ 8:06 pm
Speedy and if the developer changed the threshold of signal algorithm so in the past you could get 100% and now not anymore??
geposted Fri 30 Apr 10 @ 2:15 am
Maybe its just an indication issue. With 0% we play fine, timecoding working good.
I will never find the answer because the card and vinyls were sold yesterday.
geposted Sun 02 May 10 @ 5:58 am
Have you done the configuration with the Tutorial ?
https://virtualdj.com/wiki/TimeCode%20Config.html
Greets, Heiko
Greets, Heiko
geposted Sun 02 May 10 @ 6:00 am
Heiko, I have been doing timecodes for years with VirtualDJ original vinyls.
So, the only difference between my setup and the one I quoted is the soundcard, I have a Hercules MK2 now, but I have had an ESI U46DJ and never had troubles with then.
But now is too late. The maya and Numark hooked me up. LOL
Thanks
Thanks
geposted Sun 02 May 10 @ 6:12 am
