I bought the Hercules RMX , and I guess it has the LE version of VDJ , are there any skins that can be used with it cause all i see are for ver 5.2 or 6, also how can you create loops I want to see if I really like this before investing more money.
geposted Thu 29 Apr 10 @ 1:57 pm
i dont remember but i dont think you can use anyother skin other than the one you are able to upgrade to at the time.being that it is the le(limited edition) as for the loops you can set them via the 1-6 buttons manually
geposted Thu 29 Apr 10 @ 2:38 pm
