I can easily drag songs from within Virtual DJ, but how do I drag a song from say an outside source such as Itunes. I remember i used to be able to do this.
The reason for this is because my itunes library is just so huge and the search function within my library is a million times better than the virtual dj search function. I will search for a song I know I have and unless its in a playlist within virtual DJ it will not find it. Therefore just having the ability to search within itunes itself and dragging and dropping would be of great ease.
Thx if you can help me on this.
geposted Sun 02 May 10 @ 11:53 am
BUMP
Someone please help me, I need this support by this Saturday thanks!
geposted Mon 03 May 10 @ 3:58 pm
If you analyze all folder songs that you are going to work with in VirtualDJ, you will add all those files without doing anything else. But if you don't analyze it and don't add it to search database, VirtualDJ would not find them.
For VirtualDJ Pro search, just ADD iTunes folder or any music folder that you have to ADD to Search database. To do this, just right-click on the folder you want to add and you will have all in VirtualDJ Pro.
Hope this let you use better VirtualDJ Pro.
geposted Tue 04 May 10 @ 2:50 am
