hi guys, im working on a set for a gig i have coming up and i cant seem to find a way to dump my tracks into the playlist then once im happy with my next mix put them to oneside in the order i want to play them next time.
its bugging the hell out of me.. please help...to word it better, seeing as i just re read that total babble.
ive put my tracks into my playlist that i want to use. i want to mix them. if when i play a track im not happy about the way the mix goes, i would like to put it back into the playlist. if i am happy, then i would like to put them in order in my sidelist. without having to search for them again.
geposted Sun 02 May 10 @ 12:55 pm
Click on the red folder up top where your other folders are, then it will appear at the bottom, then name it "tonights set" or whatever you want, and then drag and drop all your tracks that you want to play.
Hope this helps
Huey
Hope this helps
Huey
geposted Sun 02 May 10 @ 2:24 pm
il try and let you know if i suss it out.
geposted Sun 02 May 10 @ 2:55 pm
hahahahaha how dumb am i???
i cant believe its that easy. one click and a few knocks on the keyboard.
thanks huey :D
thanks huey :D
geposted Sun 02 May 10 @ 2:57 pm
Yup its always the easy 1's that get us, lol!!
Have a good 1
Huey
Have a good 1
Huey
geposted Sun 02 May 10 @ 5:29 pm
