Hi,
I have recently got Virtual DJ 6, and it has been working fine until I decided to download a load of sound effects for it. Some of the effects work fine, but with others, they come up in Virtual DJ, but do not have the "Activate on Deck 1 or Deck 2" button. Some of the effects that I had before used to work fine, but now do not.
I use:
Virtual DJ 6 Pro
Windows XP Home
Thanks,
IStAmPI
I use:
Virtual DJ 6 Pro
Windows XP Home
Thanks,
IStAmPI
geposted Mon 03 May 10 @ 2:51 pm
which effects r u talking bout
geposted Mon 03 May 10 @ 7:57 pm
There are around 50 effecs in the folder... You want me to list all the ones that dont work?
Some of the effects used to work as I said... but now dont since I installed a whole load more.
Thanks
Thanks
geposted Tue 04 May 10 @ 2:03 pm
check the versions some of the effects r made for, that might be the case.
geposted Tue 04 May 10 @ 2:04 pm
Ok thanks
geposted Tue 04 May 10 @ 2:10 pm
