Looking to buy a new computer strictly for djing. Has to be a mac because I simply can't tolerate windows. Only problem is I don't have much money to spend. I found a powerbook on craigslist for $300. It has a 1.5ghz single core processor and 2gb of ram. Was wondering if anyone else was using a powerbook and can vouch that they work well with vdj.
geposted Mon 03 May 10 @ 4:58 pm
Buy it. For that price, you can always resell it quick if you dont like it.
geposted Mon 03 May 10 @ 5:00 pm
I'm quite happily not a mac guy so could be wrong but I don't think that would work, the powerbooks are before Apple started using Intel chipsets, Virtual DJ would not run.
geposted Mon 03 May 10 @ 5:07 pm
Got a PowerMac G5. No Intel processor, but VDJ works fine. What kind of problems do you think it should have?
geposted Mon 03 May 10 @ 5:10 pm
My mistake then, didn't realise VirtualDJ was PPC compatible.
geposted Mon 03 May 10 @ 5:15 pm
If it does work it will barely work, there's no way the specs on an old powerbook will be up to par for running VDJ smoothly.
geposted Mon 03 May 10 @ 9:01 pm
no it will def work for strictly audio. my old p4 processor had it working flawless for windows, that should def be fine.
geposted Mon 03 May 10 @ 9:58 pm
imo if you're gonna get a machine dedicated to music then y should it not be windows? ppl get a pc and take it all over the net and do all sorts of experiments then when it breaks down run to mac. if money is not a problem then get a mac. if money is a problem then y not get a pc and only use it for music. since u wont be taking it anywhere else it shouldnt break down.
my opinion.
my opinion.
geposted Mon 03 May 10 @ 10:35 pm
