Hi all,one very pissed off dj after some advice. Had my first gig to do at the weekend, however after hooking up my laptop to my total control and I/o that ive had for approximately a year there was a loud crack and the laptop went blank. Cue a burnt out I/o, total control and x2 usb ports. Gig off then.
Anybody know what might've happened and If I can get repaired?
geposted Tue 04 May 10 @ 12:38 pm
That sounds like your laptop or USB ports experienced a surge or a failed component.
Software cannot cause that to happen, a part will have failed in the laptop to cause that. Does the computer turn on?
geposted Wed 05 May 10 @ 5:54 pm
Yeah it turned on after about five minutes........minus both left hand usb ports and I/o and total control burnt out. Is it likely my numark gear can be repaired?
geposted Thu 06 May 10 @ 2:06 pm
It would be repairable but would be out of warranty you can get this done by the HQ in the uk.
uksupport[at]numark.com
geposted Thu 06 May 10 @ 5:05 pm
ok thanks for your help.
geposted Fri 07 May 10 @ 3:13 pm
